Sobald ich mich am Desktop Client anmelde stürzt er ab. Win10, lief bisher ohne Probleme.
Neuinstallation hat nicht gebracht.
[2021-11-23 9:28:07.004] [T6712] [Debug] [account] New store state: data::Account::StoreCreating
[2021-11-23 9:28:07.005] [T6712] [Warning] [service.store] SQL Query failed. Code: “” Message: “Parameter count mismatch”
[2021-11-23 9:28:07.005] [T6712] [Debug] [service.store] QUERY: “SELECT * FROM settings WHERE key=(:key)”
[2021-11-23 9:28:07.005] [T6712] [Debug] [service.store] QUERY: “SELECT value FROM settings WHERE key=(:key)”
[2021-11-23 9:28:07.005] [T6712] [Critical] [service.SettingsStore] Can’t query value for key “client~version” , error: “Parameter count mismatch”
[2021-11-23 9:28:07.005] [T6712] [Debug] [service.StoreService] Check versions, clientVersion: 82.1.2028 , dbVersion:
[2021-11-23 9:28:07.005] [T6712] [Debug] [account] New store state: data::Account::StoreMigrating
[2021-11-23 9:28:07.005] [T6712] [Info] [MigrationManager] Migration worker started
[2021-11-23 9:28:07.048] [T6712] [Debug] [MigrationManager] Migration step 200 finished with result 0 resync: true
[2021-11-23 9:28:07.052] [T6712] [Info] [MigrationManager] Database has been vacuumed
[2021-11-23 9:28:07.054] [T6712] [Info] [MigrationManager] Migration worker finished successfully
[2021-11-23 9:28:07.054] [T6712] [Debug] [service.StoreService] MigrationManager finished migration database with result: pc::migration::MigrationManager::Success resync: true
[2021-11-23 9:28:07.074] [T6712] [Info] [service.StoreService] Database has been vacuumed
[2021-11-23 9:28:11.084] [T6712] [Warning] [account] New connection state: data::Account::ConnectionNoCredentials
[2021-11-23 9:28:11.106] [T6712] [Warning] [service.ConnectivityMonitor] ConnectivityMonitor::onNetworkChanged called by: data::Account(0x251d228)
[2021-11-23 9:28:11.106] [T6712] [Warning] [service.ConnectivityMonitor] No credentials yet, will not check connectivity
[2021-11-23 9:28:11.196] [T6712] [Warning] [service.ConnectivityMonitor] ConnectivityMonitor::onNetworkChanged called by: service::WinConnectivityMonitor(0x42b562c)
[2021-11-23 9:28:11.196] [T6712] [Warning] [service.ConnectivityMonitor] No credentials yet, will not check connectivity
[2021-11-23 9:28:20.411] [T6712] [Warning] [account] New connection state: data::Account::ConnectionInitial
[2021-11-23 9:28:20.411] [T6712] [Warning] [service.ConnectivityMonitor] ConnectivityMonitor::onNetworkChanged called by: service::ConnectionService(0x42b4b00, name = “ConnectionService”)
[2021-11-23 9:28:20.411] [T6712] [Warning] [service.ConnectivityMonitor] network available
[2021-11-23 9:28:20.411] [T6712] [Warning] [service.ConnectivityMonitor] try to connect
[2021-11-23 9:28:20.411] [T6712] [Warning] [account] New connection state: data::Account::ConnectionConnecting
[2021-11-23 9:28:21.613] [T6712] [Warning] [service.ConnectivityMonitor] ConnectivityMonitor::onConnectivityChecked called by: service::ConnectivityChecker(0x42b5608)
[2021-11-23 9:28:21.829] [T6712] [Warning] [service.WebSocketConnectionTransport] WebSocket state changed to: QAbstractSocket::ConnectingState
[2021-11-23 9:28:21.930] [T6712] [Warning] [service.WebSocketConnectionTransport] WebSocket state changed to: QAbstractSocket::ConnectedState
[2021-11-23 9:28:21.930] [T6712] [Warning] [service.WebSocketConnectionTransport] WebSocket connected
[2021-11-23 9:28:21.930] [T6712] [Warning] [account] New connection state: data::Account::ConnectionHandShake
[2021-11-23 9:28:21.930] [T6712] [Warning] [default] QObject::disconnect: Unexpected nullptr parameter
[2021-11-23 9:28:21.931] [T6712] [Warning] [default] QObject::disconnect: Unexpected nullptr parameter
[2021-11-23 9:28:23.079] [T6712] [Warning] [service.ConnectionService] Timeout when checking “192.168.1.154” : 80 after 1000
