sub_user mode callee
-- Executing [s@sub_user:2] Goto("SIP/mdc_trunk_conf-4-00000007", "s-callee,1") in new stack
-- Goto (sub_user,s-callee,1)
-- Executing [s-callee@sub_user:1] Verbose("SIP/mdc_trunk_conf-4-00000007", "1,sub_user user id: 3 - user: s.gehr - realname: Sven Gehr - own mailbox: 10 - watched mailbox: 10") in new stack
-- Executing [s-callee@sub_user:2] Set("SIP/mdc_trunk_conf-4-00000007", "_MDC_CALLEE_USER_ID=3") in new stack
-- Executing [s-callee@sub_user:3] Set("SIP/mdc_trunk_conf-4-00000007", "_MDC_CALLEE_ACC_NAME=s.gehr") in new stack
-- Executing [s-callee@sub_user:4] Set("SIP/mdc_trunk_conf-4-00000007", "_MDC_CALLEE_ACC_REALNAME=Sven Gehr") in new stack
-- Executing [s-callee@sub_user:5] Set("SIP/mdc_trunk_conf-4-00000007", "_MDC_CALLEE_VM_OWN=10") in new stack
-- Executing [s-callee@sub_user:6] Set("SIP/mdc_trunk_conf-4-00000007", "_MDC_CALLEE_VM_WATCHED=10") in new stack
-- Executing [s-callee@sub_user:7] Return("SIP/mdc_trunk_conf-4-00000007", "") in new stack
-- Executing [10@mdc_distribute:2] Goto("SIP/mdc_trunk_conf-4-00000007", "mdc_ident-3,10,1") in new stack
-- Goto (mdc_ident-3,10,1)
-- Executing [10@mdc_ident-3:1] GotoIf("SIP/mdc_trunk_conf-4-00000007", "0?mdc_loop,s,1") in new stack
-- Executing [10@mdc_ident-3:2] Set("SIP/mdc_trunk_conf-4-00000007", "MDC_MAIN_HOP=2") in new stack
-- Executing [10@mdc_ident-3:3] NoOp("SIP/mdc_trunk_conf-4-00000007", "alias-check:: call forwarding from 10 - 1") in new stack
-- Executing [10@mdc_ident-3:4] GotoIf("SIP/mdc_trunk_conf-4-00000007", "1?10-uml,1:10-dial,1") in new stack
-- Goto (mdc_ident-3,10-uml,1)
-- Executing [10-uml@mdc_ident-3:1] GotoIf("SIP/mdc_trunk_conf-4-00000007", "0?mdc_alias-loop,s,1") in new stack
-- Executing [10-uml@mdc_ident-3:2] Set("SIP/mdc_trunk_conf-4-00000007", "__MDC_ALIAS_HOP=2") in new stack
-- Executing [10-uml@mdc_ident-3:3] Set("SIP/mdc_trunk_conf-4-00000007", "__MDC_DIALCHANNELNAME=s.gehr") in new stack
-- Executing [10-uml@mdc_ident-3:4] GotoIf("SIP/mdc_trunk_conf-4-00000007", "0?10-dial,1") in new stack
-- Executing [10-uml@mdc_ident-3:5] AGI("SIP/mdc_trunk_conf-4-00000007", "agi_roletype.php,redirect.choice,0015777532539,10") in new stack
-- Launched AGI Script /etc/asterisk/agi/agi_roletype.php
-- <SIP/mdc_trunk_conf-4-00000007>AGI Script agi_roletype.php completed, returning 0
-- Executing [10-uml@mdc_ident-3:6] GotoIf("SIP/mdc_trunk_conf-4-00000007", "0?10-dial,1") in new stack
-- Executing [10-uml@mdc_ident-3:7] GotoIf("SIP/mdc_trunk_conf-4-00000007", "0?10-dial,1") in new stack
-- Executing [10-uml@mdc_ident-3:8] Set("SIP/mdc_trunk_conf-4-00000007", "__MDC_DIALCALLERNAME=>>10") in new stack
-- Executing [10-uml@mdc_ident-3:9] Set("SIP/mdc_trunk_conf-4-00000007", "CALLERID(name)=>>10") in new stack
-- Executing [10-uml@mdc_ident-3:10] UserEvent("SIP/mdc_trunk_conf-4-00000007", "Transition,Type: mdredirect,Arg1: 01713345633,Channel: SIP/mdc_trunk_conf-4-00000007") in new stack
-- Executing [10-uml@mdc_ident-3:11] Goto("SIP/mdc_trunk_conf-4-00000007", "main,01713345633,1") in new stack
-- Goto (main,01713345633,1)
-- Executing [01713345633@main:1] ExecIf("SIP/mdc_trunk_conf-4-00000007", "0?Set(MDC_MAIN_HOP=0)") in new stack
-- Executing [01713345633@main:2] Set("SIP/mdc_trunk_conf-4-00000007", "MDC_MAIN_HOP=3") in new stack
-- Executing [01713345633@main:3] GotoIf("SIP/mdc_trunk_conf-4-00000007", "0?mdc_loop,s,1") in new stack
-- Executing [01713345633@main:4] Gosub("SIP/mdc_trunk_conf-4-00000007", "sub_defcall,s,1(01713345633)") in new stack
-- Executing [s@sub_defcall:1] Set("SIP/mdc_trunk_conf-4-00000007", "__MDC_ALIAS_HOP=3") in new stack
-- Executing [s@sub_defcall:2] Set("SIP/mdc_trunk_conf-4-00000007", "__MDC_DIALCALLEENUM=01713345633") in new stack
-- Executing [s@sub_defcall:3] Set("SIP/mdc_trunk_conf-4-00000007", "__MDC_DIALCALLERNUM=0015777532539") in new stack
-- Executing [s@sub_defcall:4] Set("SIP/mdc_trunk_conf-4-00000007", "__MDC_DIALCALLERLANGUAGE=de") in new stack
-- Executing [s@sub_defcall:5] Set("SIP/mdc_trunk_conf-4-00000007", "__MDC_DIALCALLERNAME=>>10") in new stack
-- Executing [s@sub_defcall:6] Set("SIP/mdc_trunk_conf-4-00000007", "__MDC_DIALCHANNELNAME=mdc_trunk_conf-4") in new stack
-- Executing [s@sub_defcall:7] Return("SIP/mdc_trunk_conf-4-00000007", "") in new stack
-- Executing [01713345633@main:5] Gosub("SIP/mdc_trunk_conf-4-00000007", "sub_homer,s,1") in new stack
-- Executing [s@sub_homer:1] SIPRemoveHeader("SIP/mdc_trunk_conf-4-00000007", "P-cs-cid:") in new stack
-- Executing [s@sub_homer:2] ExecIf("SIP/mdc_trunk_conf-4-00000007", "1?SipAddHeader(P-cs-cid: p65553t1503739636m797914c287182973s2)") in new stack
-- Executing [s@sub_homer:3] Return("SIP/mdc_trunk_conf-4-00000007", "") in new stack
-- Executing [01713345633@main:6] Goto("SIP/mdc_trunk_conf-4-00000007", "mdc_distribute,01713345633,1") in new stack
-- Goto (mdc_distribute,01713345633,1)
-- Executing [01713345633@mdc_distribute:1] Set("SIP/mdc_trunk_conf-4-00000007", "MDC_INPREFIX_TRUNK=") in new stack
-- Executing [01713345633@mdc_distribute:2] Verbose("SIP/mdc_trunk_conf-4-00000007", "1,remove inprefix: ") in new stack
remove inprefix:
-- Executing [01713345633@mdc_distribute:3] Goto("SIP/mdc_trunk_conf-4-00000007", "mdc_outgoing-5,01713345633,1") in new stack
-- Goto (mdc_outgoing-5,01713345633,1)
-- Executing [01713345633@mdc_outgoing-5:1] Gosub("SIP/mdc_trunk_conf-4-00000007", "sub_trunk-outgoing-5,01713345633,1") in new stack
-- Executing [01713345633@sub_trunk-outgoing-5:1] Gosub("SIP/mdc_trunk_conf-4-00000007", "sub_nat2int,s,1(MDC_CALLEE_NUM_INTERNAT,01713345633,00,49,0,7223,0)") in new stack
-- Executing [s@sub_nat2int:1] Verbose("SIP/mdc_trunk_conf-4-00000007", "1,sub_nat2int:: variable: MDC_CALLEE_NUM_INTERNAT - number: 01713345633 - intVAZ: 00 - lkz: 49 - natVAZ: 0 - onKz: 7223 - incoming: 0") in new stack
-- Executing [s@sub_nat2int:2] GotoIf("SIP/mdc_trunk_conf-4-00000007", "0?s-emergency,1") in new stack
-- Executing [s@sub_nat2int:3] GotoIf("SIP/mdc_trunk_conf-4-00000007", "0?s-int,1") in new stack
-- Executing [s@sub_nat2int:4] GotoIf("SIP/mdc_trunk_conf-4-00000007", "0?s-int,1") in new stack
-- Executing [s@sub_nat2int:5] GotoIf("SIP/mdc_trunk_conf-4-00000007", "0?s-convert,1") in new stack
-- Executing [s@sub_nat2int:6] GotoIf("SIP/mdc_trunk_conf-4-00000007", "0?s-int,1") in new stack
-- Executing [s@sub_nat2int:7] GotoIf("SIP/mdc_trunk_conf-4-00000007", "0?s-intshort,1") in new stack
-- Executing [s@sub_nat2int:8] GotoIf("SIP/mdc_trunk_conf-4-00000007", "0?s-natshort,1") in new stack
-- Executing [s@sub_nat2int:9] GotoIf("SIP/mdc_trunk_conf-4-00000007", "1?s-nat,1") in new stack
-- Goto (sub_nat2int,s-nat,1)
-- Executing [s-nat@sub_nat2int:1] Verbose("SIP/mdc_trunk_conf-4-00000007", "1,national") in new stack
national
-- Executing [s-nat@sub_nat2int:2] Set("SIP/mdc_trunk_conf-4-00000007", "MDC_CALLEE_NUM_INTERNAT=00491713345633") in new stack
-- Executing [s-nat@sub_nat2int:3] Return("SIP/mdc_trunk_conf-4-00000007", "") in new stack
-- Executing [01713345633@sub_trunk-outgoing-5:2] Gosub("SIP/mdc_trunk_conf-4-00000007", "sub_int2nat,s,1(MDC_CALLEE_NUM_NAT,00491713345633,00,49,0,7223,0)") in new stack
-- Executing [s@sub_int2nat:1] Verbose("SIP/mdc_trunk_conf-4-00000007", "1,sub_int2nat:: variable: MDC_CALLEE_NUM_NAT - exten: 00491713345633 - intVAZ: 00 - lkz: 49 - natVAZ: 0 - onKz: 7223 - incoming: 0") in new stack
-- Executing [s@sub_int2nat:2] GotoIf("SIP/mdc_trunk_conf-4-00000007", "0?s-emergency,1") in new stack
-- Executing [s@sub_int2nat:3] GotoIf("SIP/mdc_trunk_conf-4-00000007", "0?nat") in new stack
-- Executing [s@sub_int2nat:4] GotoIf("SIP/mdc_trunk_conf-4-00000007", "1?s-internat,1") in new stack
-- Executing [s-internat@sub_int2nat:1] Set("SIP/mdc_trunk_conf-4-00000007", "MDC_CALLEE_NUM_NAT=01713345633") in new stack
-- Executing [s-internat@sub_int2nat:2] Return("SIP/mdc_trunk_conf-4-00000007", "") in new stack
-- Executing [01713345633@sub_trunk-outgoing-5:3] Set("SIP/mdc_trunk_conf-4-00000007", "CALLERID(num)=0015777532539") in new stack
-- Executing [01713345633@sub_trunk-outgoing-5:4] GotoIf("SIP/mdc_trunk_conf-4-00000007", "0?searchdone") in new stack
-- Executing [01713345633@sub_trunk-outgoing-5:5] UserEvent("SIP/mdc_trunk_conf-4-00000007", "ResolveCallerName,Strategy: system,Outbound: 1,Channel: SIP/mdc_trunk_conf-4-00000007") in new stack
-- Executing [01713345633@sub_trunk-outgoing-5:6] Wait("SIP/mdc_trunk_conf-4-00000007", "0.25") in new stack
-- Executing [01713345633@sub_trunk-outgoing-5:7] Verbose("SIP/mdc_trunk_conf-4-00000007", "1,MDC_RESOLVENAME_HITS = 0") in new stack
-- Executing [01713345633@sub_trunk-outgoing-5:8] Verbose("SIP/mdc_trunk_conf-4-00000007", "1,MDC_DIALCALLEENAME = ") in new stack
-- Executing [01713345633@sub_trunk-outgoing-5:9] GotoIf("SIP/mdc_trunk_conf-4-00000007", "0?enddeflection") in new stack
-- Executing [01713345633@sub_trunk-outgoing-5:10] GotoIf("SIP/mdc_trunk_conf-4-00000007", "0?enddeflection") in new stack
-- Executing [01713345633@sub_trunk-outgoing-5:11] GotoIf("SIP/mdc_trunk_conf-4-00000007", "0?rtp") in new stack
-- Executing [01713345633@sub_trunk-outgoing-5:12] Verbose("SIP/mdc_trunk_conf-4-00000007", "1,Response 302") in new stack
Response 302
-- Executing [01713345633@sub_trunk-outgoing-5:13] Wait("SIP/mdc_trunk_conf-4-00000007", "1") in new stack
-- Executing [01713345633@sub_trunk-outgoing-5:14] Transfer("SIP/mdc_trunk_conf-4-00000007", "SIP/01713345633") in new stack
-- Executing [01713345633@sub_trunk-outgoing-5:15] GotoIf("SIP/mdc_trunk_conf-4-00000007", "0?rtp") in new stack
-- Executing [01713345633@sub_trunk-outgoing-5:16] Hangup("SIP/mdc_trunk_conf-4-00000007", "17") in new stack
== Spawn extension (sub_trunk-outgoing-5, 01713345633, 16) exited non-zero on 'SIP/mdc_trunk_conf-4-00000007'
-- Executing [h@sub_trunk-outgoing-5:1] Gosub("SIP/mdc_trunk_conf-4-00000007", "def_hangup,s,1(,,,CALL)") in new stack
-- Executing [s@def_hangup:1] NoOp("SIP/mdc_trunk_conf-4-00000007", ">>>def_hangup:: EXTEN: DIALSTATUS: QUEUESTATUS: REASON: CALL") in new stack
mobydick*CLI>
